03 IS300 shifter light
So amongst other light/wiring stuff I've dealt with, I had the centre console stuff out so thought I'd replace the shifter bulb with an LED as it had often flickered or gone off.
However it turns out the problem is most likely the holder the bulb sits in and my LEDs also struggle to stay in it, and if I put a bulb in and tap the holder it often flickers off/on again.
The other issue is my LEDs seem too long to be used since this bulb is held in the clear plastic shifter guard and when you try to clip that down on the shifter it has an annoying white plastic block point blank in front of the LED so it just knocks my LEDs out of this loose bulb holder.
Anyone got any tips or parts I can use?  I could try to put it back together with the original bulb but it's still going to annoy my if it keeps going off cos of a looser holder or whatever  😞
Attached a pic showing where the bulb is held in the guard, and compared to the LEDs I have spare in size
So I played around some more and also found the domed LED don't fit in the ashtray space either and the no-domed ones are too directional upwards whereas they need to go sideways.
I may be able to squeeze a non-domed one into the shifter light spot but I'm fairly sure there is an issue with either the holder's connectivity causing them to flicker (multiple bulbs) or the wire going into it.  I don't really have a way to test 😞 But I'll at least need shorter but side illuminating LEDs if possible?
I thought maybe I could trim the top off the plastic but there is a little resistor or something on 1 of the wires from the bulb in there so I can't save any vertical space that way  😞
2 hours ago, rich1068 said:
Is this a light that indicates P, R, D etc next to the gear lever? I'm almost certain I've never seen that illuminated on my IS300. I'll have to check.
Yes.  At 13.00 in this video you see him replacing it even though he wasn't going to.  My issue is 1 the LEDs seem to stick out too far and 2 the socket/wire seems to result in an intermittently flickering bulb so I dunno what I can do about that - I don't wanna put this back together and have a flicker  😕
If anyone has experience with this light, or knows where I can buy LEDs that fit (same for the ashtray that also doesn't fit my dome one and the direct one doesn't really light it) that'd be great.  I don't think I'll be bothering to remove the wired-in cigar lighter light for an LED though it looks simple enough in this video
I believe for LEDs the resistor stopping them blowing is what you see inside the plastic plug casings (which stops me shortening their length which I need to do for some of these sockets, as seen in the pic below.
The bulb holder that goes behind either the RPM or Fuel gauge is the blue one in the pic below - where can I buy these?  The issue may not be the holder but where the holder rubs on the board as you twist it in - I'm not sure how I can help that connection if it's the issue  😕
Video attached shows my current issue with the shifter light as it seems to go off when twisting the holder.  Will I need to chip & replace the wire, refit the wire into the holder (it looks pretty fixed/ok) or what? 🤔
Does anyone have any links for LEDs that are super short so they can go in the shifter socket (but also spreads out sideways not just end on which is point blank at a plastic lump)?  It needs to not stick out anymore than the orange covered bulb shown below.
Does anyone have tips on how to fix that light going off when I turn the socket in the video above?  The 2 wires into the socket look pretty stable/fixed and don't move so I don't know what part where is the issue.  I can't see a way to get the wires out and stripe the ends and refit them - are there pre-wired sockets I can buy that I can then join the wires up?
Does anyone have any links to replacements for the blue holder you see in the 2 pics below?
  • 2 months later...
I believe these are the ones
https://www.ebay.co.uk/itm/5-x-Toshiba-V2-V-2-T5-Bulb-Holder-Dashboard-Instrument-Panel-HONDA-TOYOTA-MAZDA-/182824695958?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=710-127635-2958-0
