Lambda Bypass Controller
Usually007
What are you trying to achieve?
We can supply 02 simulators to prevent the ecu warning light coming on, but to map the Unichip for cruising etc means you need to switch the lamda's off, which (as far as I know) can only be done inside the standard ecu, and I don't know anyone that can do it.
Hello Mark,
You did warn me a while back when I discussed getting a supercharger that you liked to check the fuelling.
My rolling road engineer reckons there is more horsepower to be had with the Unichip Supercharger combination if the lambda sensors didn't stop the ECU under fuelling.
He recommended Lambda sensor and water injection.
What do you think????
Hello Mark,
I still don't really understand what you mean, but water injection injection will not affect the fuelling or give you any more power.
I never comment on what other tuners say, so I will leave you to make up your own mind based on the balance of probabilities :)
