Advice for buying an LS460 2009?
in my old and ancient Ls400 I'm using E5  ,  even that varies between 97 and 99 octane too        Esso and Tesco E5 is 99       Morrisons seems to be 97
1 hour ago, Haywire23z said:
Thanks for everyone's help, I bought the car and very happy with it. 😄
Which fuel grade would you recommend? Dealer said standard is fine but I'm using premium unless I can confirm that
Which one did you buy?
Cars built after Nov 07 are fine to use with E10, but even though your car is first registered in 09 I'd still check.  It was the time of the economy crash, and suddenly in 07 Lexus found themselves with too many LSs that no one could afford to buy.  The only way to be sure is to check your VIN with Lexus, but alternatively, pull a tag out from the bottom of a seatbelt.  This will show the date the seatbelt was made, which will then give an indication of when the car was built.
Another clue is the adaptive cruise.  Earlier cars have adaptive cruise that goes all the way down to stationary, whereas later ones the adaptive cruise turns off at a certain speed.
