Evening folks,
I have an Engine light showing, it indicates the O2 sensors need to be changed. Can anyone signpost me to where I can purchase these items from please? My garage tells me they are on back order but he can’t source them.
Can anyone of you help please?
JJTJ
1 hour ago, Jollyjacktarjack said:
Many thanks Herbie, can you confirm there are 3 x O2 sensors on my 2005 RX400h please?
This is from the RX400h workshop manual Jack:
4 but you should only change the ones that are faulty - possibly the two upstream sensors together as they could fail within a short time frame of each other.
What error code(s) do you have, did the garage tell you?
Many thanks Herbie and Colin B!  I read the following on my VeePak OBD:
Car Scanner ELM OBD2
DTC report
Selected brand: Lexus
============1==============
P0037
Raw code: 0037
ECU: Engine control unit
Status: Confirmed
OBDII: Heated oxygen sensor (HO2S) 2, bank 1, heater control - circuit low
Lexus: Oxygen Sensor Heater Circuit Low Input (Bank 1, Sensor 2)
============2==============
P0037
Raw code: 0037
ECU: Engine control unit #1
Status: Confirmed
Still unsure which sensor this actually relates to please?
Thanks,
JJTJ
  • 1 year later...
Evening Folks,
Update on the issue below - changed the O2 sensor (sensor (HO2S) 2, bank 1) and the car ran great for 18 months. The same code reappeared in Dec 23, changed the same sensor and it cleared for a week, sent that sensor back and bought another, ran great again for 1 month.  Today the following popped up:
P0138, P3190, P3193 and P0A0F
The car ran rough for a bit, stopped and restarted. Continued home and all appeared to be running OK, the Check Hybrid System lights remained illuminated though.  Any thoughts please folks MAF, another sensor change,Hybrid Battery starting to fail...?
Thanks JJTJ
Update Folks,
MAF cleaned, as well as the air filter.  Car driven this morning and all was well until the car had warmed up, the old symptoms of the car appeared, ie a selection of beeps and warnings and being forced to limp home on the hybrid Battery (the engine does restart if you switch on and off though) above codes are still present as well as some new ones - C1259,C1310.
Anymore thoughts before I think me and my trusty Lexus have to part ways please?
Thanks,
JJTJ
This all seems engine related. It really needs a proper diagnosis by looking at all the sensor data, especially when it goes into a fault condition - otherwise you will be guessing. Worth checking that state of all the vacuum hoses in case they are perishing and open up when they get warm. It could be related to the MAF and O2 sensors, but you really want to narrow down what the problem is rather than throwing money at it by replacing parts that aren't faulty.
On 1/10/2024 at 8:27 PM, Jollyjacktarjack said:
Hybrid battery starting to fail
I don't think so. The faults related to hybrid are because the engine is failing to start - the same as those two new codes, they typically appear when other problems exist rather than being the root cause themselves. Worth checking you don't have water ingress in your boot though, as it is a common issue on older 400h vehicles.
Thanks for the response Colin, much obliged.  I do get water ingress, common with this model.  In wet weather it gets a cover placed over it!
To the vacuum hoses, assume these are the ones to/from the air filter area please?
Thanks,
JJTJ
