WATERLESS COOLANT
ahmed-abrar
Can't see the waterless coolant having any detrimental effects. Ed China has kind of recommended it.
Trouble is if you've got it in your car and took it to service and forgotten to mention it then they either top it up with 'normal' coolant or flush it out and replace with 'normal' coolant.
When I looked at the stuff it was quite expensive.
1 hour ago, Mr Vlad said:
…Trouble is if you've got it in your car and took it to service and forgotten to mention it then they either top it up with 'normal' coolant or flush it out and replace with 'normal' coolant ….
Never used waterless coolant, but I once picked up an advertising leaflet from a display (?-Evans) and seem to remember they supply a reminder sticker for the reservoir cap.
