IS300H 2014 Defrost Windshield Issue
Phil0671
Hello everyone.
I've found few issues with the ventilation system.
The first one is that the central console never keep in memory my fans settings and the digital panel stay black during one or two minutes after the electrical power is on (annoying when it's 50 degres Celcius outside
Also, when it's raining and the is some "high level" of humidity inside the car (wet clothes or other), the windshield fogs up, so i use the defrost function on the dashboard, we can hear the blower working but a very small amount of air is getting out from the air vents.
I think the cause could be from an orientation flap that is stuck behind the dashboard.
So my question is. Is there a way to get access to those flaps without removing the central console with the dashboard?
In advance, thanks for your help.
Sounds like you have multiple issues with the climate control that will need diagnosis, using Techstream but do you have the a/c switched on? This will dry the cabin air quite efficiently especially if you can use the recirculation function.
