Hi all
I am in the process of getting apple Car Play fitted to my 2018 GS 450h but have a few concerns
I have seen the Carlinkit system here for around £350 and the info on the site doesnt look too bad however I like to have Nav on one side (the largest part) and Range ,Time and MPG on the other, does the carlink allow this as all the photos shows either Full screen Nav or Full screen Icons.
I have looked at the beatsonic but  its around £900 a bit out of my range, maybe because there are'nt too many GS s  here
I have looked on line at the images but i could'nt get a definitive conclusion from the display.
I do on occasions Have full map on screen and use the small dial in Dash but prefer the main screen.
I do also have the Quick Dial window up as well so i dont want to lose the ability to have no display on the Main screen.
I would be obliged if anyone  could enlighten me on this topic
Regards
I can't speak for the unit you are referring to but I recently bought a wireless Android Auto dongle from Carlinkit.It did not work as it was advertised and I had to return it.Carlinkit customer service is abysmal and I wouldn't have anything to do with them.other members on here have had similar problems with them.
Thanks For the Info David
I did read on the US site that it was a bit clunky and a pain to setup
but i am sure there must be a kit that is  compatable
Thanks all the same
Robert
I've got a Grom Vline2 in my RX but some people have gone with Lexion or Lsailt
Thanks for that Herbs
But my origional concern was does it take over the OEM system as i like The info on the side screen and map on larger part of screen
TIA
Robert
