Sign in to follow this
RedLexus
Dampers Question
are "Sport" dampers the same as standard ones ? I've got the -30mm Eibachs , but reckon the car needs 'firming up' now in the damping control. I've only used Konis on other cars , what's a nice set to go with the springs I have? ie not too much firmer?
The sport suspension is 15mm lower than standard due to springs. I think the shocks are the same.
You can go for Bilstein or Koni Yellows (adjustable stiffness) with your Eibachs
as above
but the shocks are different
I have 2 sets of suspension here, 1 x 2001 SE, 1 x 2002 Sport.
Respective shocks from each set have identical part numbers.
as above
Sorry Mat , I don't follow ...Are the Sport and standard dampers different , or the Konis and Bilsteins very different???
Thanks for the help anyway gang. :)
