Lexus Transmission Problem
rzarectah01
Don't know your particular model but it sounds as if the shift lock mechanism is kicking in when it should not. It is to stop you shifting out of park without your foot on the brake. If you have your foot on the brake does that help? Some models also have a manual shift lock over ride switch - try that.
