Sign in to follow this
rhosneigr
Hid
Is there any way of manualy adjusting the lights on the IS300. There is approx a 2 metre dark area in front of the car and they do attract quite a lot of flashing from oncoming cars.
:huh: is ther not a adjuster right hand side of your steering wheel like on the is200 ??? if not then dont know soz :huh:
The Hid headlights are automaticaly adjusted dependent on the vehicle load, but I thought there might be a way of getting an initial setting manually.
There should be manual adjustment to get the alignment correct then the self leveling system will work correctly.
Take you car back to your dealer and get them to check it for you.
Thanks for that, so there is no way to DIY then.
