Vss Wire
Does anyone know yhe exact location of the speed sensor wire on a 2001 is200 se manual, prefereably not behind the clocks. I have searched the net and there are a lot of conflicting results. How can you test it with a multimetre, do you put it on AC or DC. Thanks
Have you seen the amount of wires in the footwells!! How do you know which one? I have found a white wire with a blue stripe on it coming out of the ecu under the bonnet, would that be the right one?
