Fire Hazard
SHAHZ
This is doing the rounds....
This was received from a friend in the home insurance business.
> > > It is well worth reading.
> > > This is one of those emails that if you didn't send it, rest
> > > assured someone on your list will suffer for not reading it.
> > > The original message was written by a lady whose brother and his
> > > wife learned a hard lesson this past week.
> > > Their house burned down.... nothing left but ashes.
> > > They have good insurance so the home will be replaced and most of
> > > the contents.
> > > That is the good news. However, they were sick when they found
> > > out
the
> > > cause of the fire.
> > > The insurance investigator sifted through the ashes for several
hours.
> He
> > > had the cause of the fire traced to the master bathroom.
> > > He asked her sister-in-law what she had plugged in the bathroom.
> > > She listed the normal things....curling iron, blow dryer.
> > > He kept saying to her, "No, this would be something that would
> > > disintegrate at high temperatures".
> > > Then her sister-in-law remembered she had a Glade Plug-In in the
> > > bathroom.
> > > The investigator had one of those "Aha" moments. He said that was
> > > the cause of the fire. He said he has seen more home fires
> > > started with
the
> > > plug-in type room fresheners than
> > > anything else.
> > > He said the plastic they are made from is a THIN plastic. He also
> > > said that in every case there was nothing left to prove that it
> > > even existed.
> > > When the investigator looked in the wall plug, the two prongs
> > > left
from
> > > the plug-in were still in there.
> > > Her sister-in-law had one of the plug-ins that had a small night
> > > light built in it.
> > > She said she had noticed that the light would dim and then finally
> > > go
> out.
> > > She would walk into the bathroom a few hours later, and the light
would
> be
> > > back on again. The investigator said that the unit was getting too
hot,
> > > and would dim
> > > and go out rather than just blow the light bulb.
> > > Once it cooled down it would come on. That is a warning sign. The
> > > investigator said he personally wouldn't have any type of plug in
> > > fragrance device anywhere in his house. He has seen too many homes
> > > that have been burnt down due to them.
> > > the contents.
> > > out
the
> > > cause of  the fire.
hours.
> He
> > > bathroom.
> > > started with
the
> > > anything else.
> > > even existed.
> > > left
from
> > > light built in it.
> > > go
> out.
would
> be
hot,
> > > and would dim
Your right about this but leaving your mobile on charge all night is just as dangerous. TVs left on standby cause loads of fires each year as well as loads of other electrical things. Best bet is to get a smoke detector ( or 5 ) and invite your local Fire Brigade around for a home risk assesment. They'll fit them for you free with the bill picked up by Tony Blair.
