I wonder has anyone had a problem with the air-vent controls. On the touch screen I can alternate between the functions but unfortunately this does not seem to help. The air blows constantly through the central dash vents. The AC controls the temp. OK, but even putting on the screen demist will not divert the air flow. Has anyone encountered this problem before? I'm due to take this to my local Lexus dealer but would like any help that can be given,
Thanks.
:mat:
is it your cold air feed from outside thats blowing thru?
try the recirculate mode?
I dont really know much about the RX aircon system
but on my IS and GS theres air that comes thru seperate vents near the windows that comes direct from outside
No its not the outside air. The central vents seem to be only switched off using the control dial, with the mode chosen shown on the screen. No matter what mode is chosen the air continues to come only through the dash vents. It looks as if the controls are not responding although the screen is showing the changes input!
Many thanks for all the suggestions. My local dealer had a look and freed the motor up. The car had been sitting for a month and for some reason the motor, which redirects the airflow had stuck in one position. It is recommended to run through the program every so often to keep it free.
