WHATS A COILOVER??
uzziz
The term "coil over" has been b*st*rdised over the last 10 years or so.
It was used to differentiate between suspension systems that had separate springs and shocks, like a leaf spring or double wish bones, and systems that had the spring integrated into the shock, ie the spring is on the shock.
As most suspension systems nowadays have the spring on the shock anyway, the term "coil over" is generally now used to differentiate shocks with an adjustable lower platform that allows ride height adjustment.
Hope this helps
Mark :)
