Getting Chiped
It's some sort of resistor that fools your ECU into thinking the engine is sucking in colder air than it really is.
Very suspect claims as no one has ever come up with a before/after dyno chart.
Save your cash for something that is proven to work
Depends what you want mate, supercharger kits are proven and give 53bhp extra, if you don't want to have that outlay then you could go down the route of upgrading the exhaust, intake, remove the precats and maybe go for an aftermarket ECU but they are all more beneficial when used in conjunction with forced induction.......
not mechanical minded mate that was just double dutch to me where could i go to get some of this stuff do in hertfordshire
What sort of budget do you have and what sort of power gains are you looking for?
If you speak to Prolex-UK or TDI they should both be able to help you out with a location in your neck of the woods.
