Rx Under Engine Cover
It doesn't reduce the clearance by hardly anything so no problems. Would take a pic for you but it's P*****sing down outside. Should already be on? Standard factory fit isn't it?
Not standard fit as far as I'm aware, it's described in the list of accessories as:
Under Engine Cover
Silver...................................................................PZ415-K0951-00
It is a straight swap for the existing black one.
It just gives a silver flash under the grill instead of the black you normally see.
Lexus Sheffield have 3 fitted to vehicles on their forecourt so a pop down to your local dealer might give you a good look.
