New Member Is300,auto Working Ok?
Tiptronic is the gear range eg the highest gear it will change up to, so when you select "2" it gives both 1st and 2nd. Boot it and you will get low and then it will change up to 2. That's how mine works anyway.
ps welcome to the club
That's correct, you don't get the 1st Gear.
It stay @ [2]
However, it does start in 1st .......... then it just wont go further than 2.
Then you can go up through the gears ............... it won't let you change down a gear, for example ........
if your red lining 3rd gear ......... the e-shift won't let you select down to [2]
............ Welcome to the IS300 Club , oh ... and LOC ! :D
Welcome! :D
I never bother with the manual mode - it changes up quicker set to full auto
I use manual on twisty roads when scrathing, to use a bike term. If you use manual it won't change up when you brake going into a corner and is in the right gear to nail it out :D :driving:
Welcome! :D
Mmmm, I like manual mode - does anyone use the POWER facility on their auto - do you notice much difference???
Welcome, fellow 300 buyer - i feel the tide is beginning to turn
:D Welcome to the club.
Gib:- I leave mine in power mode all the time, i think it give the car a wee bit extra and I run with the gearbox in manual 75% of the time and only use auto while on the motorway :D
Welcome! :D
Yeah - the little red needle heads to the right at an alarming rate!
