Brake Light Conversion Available Again!
Rob
hi all, I have been asked by Mat ( due to recent enquiries) to start producing the brake light conversion kits again.
If ur interested or want a bit more info then contact me so i can get ideas of numbers.
the kit enables the middle fog light filaments to come on with the brake lights, but u retain the function of the stock fog light as normal. so u will end up with 5 brake lights.
please note that thisis not road legal ( wont pass an MOT) and as such is only for show use! :P
cheers rob.
no probs - if u go the forum archive, and do a search for "fog light mod" - it might be in the workshop/ audio/visual section?then there should be a full schematic of the required wiring loom. you will need to obtain some rectifier diodes of about 1A also you need 3 for this mod.
just let me know if u need some help.
cheers
Rob.
cheers
Rob.
hi Rob,
i can't find the diagram there. could you post the wiring diagram to my email - johnlee2002@myrealbox.com
thanks. :D
