Hi guys,
I've just been quoted (by Lexus) £77 +VAT for a coolant header tank for my 1990 LS. I then tried Toyota, and once again went through the 'banging my head on the table' thing when I had to explain that Toyota and Lexus are one and the same, and that that LS400s are also badged as Toyota Celsiors etc. etc.
Upshot: without a part number, Toyota can't (or won't) help, and so at the moment I'm looking at best part of £100 just for a plastic tank.
Any info would therefore be most gratefully received.
Thanks in advance.... :yawn:
A Toyota dealer does not have access to the lexus order or parts recognition system so they would not be able to help you :whistling: . They could get you a part number for Celsior tank but it might not fit your car.
With regards to what youve been quoted £77+Vat is nearly 20% off retail price as long as it is the expansion tank you need and not the header tank that sits on top of the Rad
Hi guys,
Hi Gecco,
Would that be a picture of you, by any chance? :D
The tank I'm referring to is the one between the relay/fuse box and the front suspension mount.
Cheers,
R
Hi Gecco,
Cheers,
R
Richard, has the tank split.
Hi Gecco,
Cheers,
R
It was taken on one of my better days :blink:
The tank you need is the expansion tank, part number is: 16470-50012. Retail price is: £94.59+vat.
Plus the Celsior tank is a different part number: 16470-50030 and retail is £75.54+vat but i doubt it will fit
Thanks, will bear in mind. Out of interest, do you know what the difference is between the LS and Celsior tanks?
Cheers....
£100 is hardly a lot to pay to prevent that fine motor from being cooked if it looses all the water.
But I do take your point that £100 is a lot for a plastic tank.
I used to have a rover 800, replacement water expansion tanks were £45 for a replacement, breakers were nearly void of them as they were notorious for splitting under the sustained pressure. I know that some enthusiasts have had aluminium tanks made up at quite a cost to stop it ever happening again.
Cheers....
Sorry mate don't know what the difference is between the two, Lexus can't tell us the difference :huh:
