Rubbing Sound!
puresilk
I was wondering if you could help me?
I got an IS 200 SE 99/T done 55K with FLSH!
The other day I was driving and noticed when i turn left i can hear a slight rubbing noise!
Its fine when i turn right!
I checked my tyres and all looks in order, what can this noise be?
Do you have the standard 17" alloys?
If you go for bigger wheels or the incorrect tyre size/offset you can get rubbing. It is usually just the plastic arch liner and nothing to worry about.
You can always heat the arch liner up and push it back if need be. :D
Yeh my standards 17" lexus wheels are still on! and make a slight rubbing noise when i turn left but not right??
Is it with full lock on only, or almost full lock  or any turn ?
If its with full lock on, turn it, get under and have look to start with - see if anything is touching the wheels or tyres  that should not be.
only when its full lock! I got it booked in for a service today so ill see what they come up with as I asked them to check it out?
