Hi and welcome to the LOC.
Have a look through the LS400 section on the main forum page,the dash is a common problem with that model,if you cant find what your looking for have a look through the LS400 section on the US forum,the link to that is at the top of the page.
Cheers chips.
Known fault on early models, especially when cold.
There is a step by step fix on the USA LOC.
The original post was by Cole Carter.
You have to replace three capacitors on the circuit boards behind the
instrument panel.
I have done this fix on my'94 LS.
If you can solder tiny parts you can do it, I got the caps. from Maplin. :)
instrument panel.
cheers mate spoke to auto electrician and gave him the info i got from this site so he'll get it fixed for me this week and cheap as he winna have to check everything n dismantle bits that dont need to be THANKS
