Calipers
swfcdan
Apologies for my lack of techical nouce but here goes anyway,
The rear calipers on my car and everything that is attached behind the wheel at the rear is v rusty. Can you suggest anything that will make it look better for example is there paing you can buy etc?
this is a very common problem.
many people simply paint their calipers with hammerite.
its cheap and very easy - use a wire brush to remove the surface rust and wipe clean using something like isopropyl alchohol, and paint.
depending on the colour you use - it can look good too.
If you like - the club has Lexus caliper stickers which you can apply once the paint has dried (simply apply some heat resistant clear laquer on top).
