The external weatherstrip can be purchased for £23+vat. Lexus charge £95 p/h. The Glass panel takes half an hour to remove and refit the new weatherstrip takes full 1 hour. Can people recommend an alternative. I really cant afford the labor costs at present & has anyone done this already. Thanks.
Hello Colin. Sometime ago I posted a similar note. The rubber seals had become hard and brittle last winter and now bits are starting to break off. Its not so much cosmetic as was the case last year even so it looks bad but I dread any leaks into the sunroof although it will remain firmly closed this winter. Not having a garage I am not comfortable of trying it myself unless its easy and quick.
