Throttle Bodys
Robin H
  • Replies 56
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Thanks for the info Mat
if you fitted new cam shafts and pulleys would you be able to run on the standard ecu would it just be the case of resetting it or would you need a new/piggy back ecu
if you run with the pulleys, you would need to diusable the vvti, so you wouldnt be able to use the ecu
however the cams can also be used without, the cam pulleys, and still keep the vvti
why is this?
anyone got a link to explain or a brief description would be a great help as this is all becoming new to me
what benefit do the pulleys have when fitted?
so with TB's you couldn't run a vvti set up, is this the same with turbo and supercharger set ups?
would it pay to fit a new ecu at the start if the build and then tweak it when new parts are fitted,
the only reason I ask this is because of the time scale of the build
or would you notice the changes throw the standard ecu?
thanks for bearing with me
why is this?
In an nutshell with vernier pulleys you can manually adjust your timing to open and close the inlet and exhaust valves earlier or later to optimise the cycle at different ranges obviously vvti changes the valve timings to keep as good as they can through the range but non vvti you have to pick the best settings for the way you want to drive the car with verniers you can select the best timing on the valves for the way you want the power to flow
Ideally you want the inlet valve to close as soon as the piston reaches the bottom of its stroke and the exhaust to close at the top of the stroke and both to be closed on ignition etc
http://www.keveney.com/otto.html
see that as i am confusing myself writing this
