Valve Clearance Check
Lexus Jim
Be surprised if the cam shaft bearings are part of the rocker cover mate.
Only engine I know that does that is the old Honda "4" motorbike engines.
I'm not sure Toyota/Yahama have used both systems. It's probably over on the IS200. I believe it's under on the RS200 engine because shims used to fall out at very high engine speed on older revisions of the engine so they changed the system.
