Door Sill Problem
i've recently purchase the stainless steel door sill from XXXX for 120 pounds,but they just so annoying, no matter what you are using to stick on, they just can't stick properly,everytime after i wash my car, they all looks like unstick...i am just so mad....and don't think i can't go back and refund them!
anyone can help?? :crybaby::crybaby:
First of all give your sills and sill plates good clean with water/vinegar solution or a good degreaser. Then use silicone sealant to stick your sill plates down.
There are various types of sealants, I'd go for something like window seal which will be weatherproof and will withstand hot and cold temperatures.
Alternately you could try an automotive gasket seal.
