Adding Power Module To Is200
Hi guys, I have just seen a power gain module (chip) on ebay, it says it increases bhp by 15, I was wondering if anyone has tried one of these and whether it is ok for the engine to run on, and if they actually work.
It basically says that it tells ECU that the incoming air in the intake system is cold and so advances the ignition to compensate producing more power.
any help appreciated!!
thanks
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
