Took my car up the strip today.
1st time since I fitted the induction kit and have lost 1/2 a second on the 1/4 mile.
Car was serviced last week and a new battery installed.
Re-set the ECU after half-a-dozen runs and it made no difference so it will be coming off tomorrow.
I even took out my golf clubs and spare wheel (which I ran with the last time) :blush: to lighten the load.
15.88 is still my best time. Anyone else got any times for a MkII 300 sport?
Remember that although an induction kit may allow the engine to draw more air.....unless it is effectively shielded/insulated then the chances are that it will be drawing more HOT air. HOT air = reduced performance.
Do you have a picture you can post up of your intake install?
I had a similar problem on my IS300 but cured it with a DIY heat shield and insulation.
Yeah mate.....there's a pic on Maneesh's thread on his kit.
I have installed a shield at the cone but guess it's just not good enough. It's a bit tight for space but as I've said elsewhere, it sounded worse, so was always a bit skeptical about it's ability.
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
