Sign in to follow this
Nicky_Chill
2jz-ge And 2jz-gte
Ok i have a question. Can anyone please tell me the main differences 2JZ-GE and 2JZ-GTE? Came up in a discussion and i felt like a dolt! So please help!!
Oh and don't all you clever asses go telling me that the GTE has twin turbos :P
Different internals and compression ratios on the GE and GTE as the GTE is fed by the turbos it has a lower compression ratio, different pistons and rods due to the heat from the combustion cycle and different throttle bodies. A few things are positioned differently too and look a bit different
What's the size of the TB on the GTE?
Has anyone ever fitted an 80mm LS400 TB to either a GE or GTE?
I thought the only difference was that it was a Turbo ........ :yawn:
Mike what you want is an Infinity Q45 90mm throttle body ;) plenty of adaptors available too if its not a straight fit
I think the throttle body is about 3" so roughly 75mm although i could be wrong i am taking an educated guess
Hmmmm......sounds interesting
That works out approx 45% bigger!
yep the q45 is the biggest you can get, i have one sat here...i also have a mustang throttle body if you want to go at fitting that it has a opening of 120mm
So is the Q45 TB a direct fit then Mat?
So is the Q95 TB a direct fit then Mat?
nope an adaptor is needed, the mustang one certainly isnt......
but it would fit your N/a inlet manifold better than the supras one...if you was interested as it could be mounted directly to the plenum, as it sits along the line of the engine....comes with TPS aswell
whereas the q45, sits on the end of the plenum, so would be an easier fit for my needs
Edited by Monster-Mat
Custom really? wasn't sure if i had seen them pre fabricated i'll bow to your knowledge matt
Ebay US is another place to pick up the 90mm throttle bodies
OK...some confusion here :blink:
Could either of you point me in the direction of either a custom or off the shelf adaptor?
Lol i'll bow to matts superior knowledge he pointed me in the direction of these throttle bodies a while ago i may have seen one being sold with a custom adaptor which is what may have thrown me
but the Q45 TB is not a fly-by-wire TB so it won't work without some major modifications to the whole sheebang. If I were you I'd take a look at the Vertex or Soope TB's
