Sign in to follow this
batman_1
Lexus Is200 - Fog Light
Bit of a PITA this one:
You'll need to jack the car and remove the front wheel to allow access to the wheel arch liner. Pop out the studs which secure the front of the liner and peel it back to allow access to the back of the fog light. You can then remove and change the bulb.
thought as much, i was hoping there was an easier way - need to get a repair manual for the car too, like the haynes manuals - any idea where i could get one from - dont even mind if its in pdf format
Haynes dont do one :o i think you can get from lexus but cost ££££££s to buy :blink:
dont need to remove the wheel, just turn the wheel so you get maximum room.
Just trying to make life easier for the dude....
thanks guys will give it a go later - thinking of getting some mudflaps for the car - do they look any good? anyone got any pics for them, actuallyon the car
Also dont worry if the bulb is hard to remove or corroded into the fog light unit. Mine was.
the way i have always done it is by just removing the bolts on the side of the fog light that holds it too the bumper and pull it out, replace the bulb and put back... simple :D
Yeah, and that's fine if you have one of the models (earlier ones, I beleive) where they are accessible from the front........
