Key/immobilizer Programming!
Hi Guys,
1st..great forum! I have used the search feature and found answers to many of my questions. However there is one that I'm at a lost on. I have a new key that was cut for my 1998 gs 400, its the US model..dont know correct terminology :)..So the key makes everything in the car come on but it will not start the car, and remote will not work. I was told by the dealership that I could pay them and they would program it for me. But I know there has to be a way to do it myself. I have a master key that works excellect...but its my only key. So if anyone has DIRECTIONS on the steps needed to program the key/immobilizer so that it will start my car I would be real thankful.
Thank guys for all the help!!!!!!
ODUFOX
Current Car Rating:
BMW.....4
BENZ....6
LEX.......95,465,484,651,846,516,841,654,641,685,163,864,884,168,467,645,656,468,765,468,416,848.00
:D
> *_How to Program Lexus Transponder Keys new and old to your car_*
> *_ _*
> *This is for the chip inside your key that starts the car*
> *Process works with all keys - remotes, valet, non-remotes
> 1. Enter the car with a working pre-programmed key and close all doors.
> Simultaneously depress and release both the brake and the accelerator
> pedals.
> 2. Within 5 seconds, insert the working pre-programmed key into the
> ignition. DO NOT TURN THE KEY.
> 3. Within 15 seconds of inserting the ignition key, depress and release
> the accelerator pedal 5 times.
> 4. Within 20 seconds, depress and release the brake pedal 6 times.
> 5 Within 10 seconds, remove the working pre-programed key from the
ignition.
> 6. Within 10 seconds, insert the pre-programmed key back into the
ignition.
> 7. Depress and release the accelerator pedal one time. The security
> light should now begin flashing to indicate that the computer is reading
> the new key and programming the system.
> 8. Leave the new key in the ignition for at least 60 seconds. When the
> security light stops flashing, the programming process should be complete.
> 9. Test the new key. Place the key into the ignition and verify that the
> car will start.
> 10. If this is a new remote master key, test the remote functions on the
> new key.
> *_
> How to program Lexus remote keys for locking/unlocking doors etc_*
> *_ _*
> 1. Sit in the driver's seat and lock all the doors.
> 2. Unlock and open the driver's door.
> 3. Insert the key into the ignition and remove it (don't turn it...just
> remove it).
> 4. Using the MANUAL lock switch on the driver's door, lock and unlock
> the door 5 times.
> 5. Close the door.
> 6. Open the door.
> 7. Lock and unlock the driver's door 5 times (I'm almost certain you use
> the MANUAL lock switch again, but if this sequence fails to work, try
> again with the power switch).
> Insert the key into the ignition and turn it to the "ON" position.
> Remove the key.
> 8. The driver's door will now lock and unlock itself one time.
> 9. Press and hold the "LOCK" button on the key fob for at least 1 second.
> 10. Close the driver's door.
> 11. Open the driver's door.
> 12. Press and hold the "LOCK" button on the key fob for at least one
second.
> 13. Close the driver's door.
> 14. Press and hold the "LOCK" button on the key fob. The door will lock.
> 15. Press and hold the "LOCK" button on the key fob again. The door will
> unlock.
> You should be all set.
MERRY XMAS AND HAPPY NEW YEAR ALL!!!
JEFF
