Fmic....
jackal
Its fine - I have this model fitted in mine, no problems at all. :D
All the best Paul.
How easy is it to fit was thinking of doing it my self :unsure:
Was there any modifications needed to make it fit?
Yes, you will have to cut the bumper and use mesh.
Or buy a proper front bumper from Veilside or Quest Power.
If you are going to take your car to circuit, then the front mount IC will compromise your cooling and lead to over-heating quite possibly (problem I have). No problem running it on the road however.
It'll increase lag slightly, but increase HP by about 20hp. However, the front mount IC is essential if you go for turbo upgrade and will also supply adequate air for the turbo should you wish to run high boost.
All the best Paul.
Hi Yoshi,
Have you tried doing some ducting to lead more air to the radiator? Brakes? ATF & Oil Cooler? Just curious...
