New Clutch's: Any Recommendations?
corsavandal
Look at buying a blueprint clutch system, this is good as OEM. I think prolex will stock it, check their website for price and avaliability.
btw- I notice your from Leeds, whereabouts? I'm orginally from Pudsey, but have moved to Ilkley.
will do.
Im living in Yeadon now. good move from Pudsey! been out around there a couple of times and it always ends in an early finish due to :tsktsk: heads
will do.
Ive a squeaky clutch to but its fine, just down to the linkage i think. A bit of lube should solve this. You don't feel the clutch slipping or anything do you?
no no, stays in gear fine!
The gear linkage went on my corsa and i found it very difficult to get into 1st and the stick itself wobbled quite a bit. got it done under warrenty and problem solved, gear stick firmed up and no more fighting to get into first.
Ye im not saying the linkage is gone, its just gotten a bit squeaky. some grease on the linkage should sort that out i think
linkage the bit under the leather gator??
No thats the gearbox! :winky: Think you need to jack the car up to get to it under the car, not exactly sure where it is, will be having a go at mine over the weekend maybe
I had the BluePrint clutch fitted in my IS, had it on for quite a while with the supercharger and then for around 10k without after the SC was removed and it was great, couldn't moan about it at all :)
That came from Prolex-UK and was fitted over at Charlesworth Motors :)
could you take a pic and post it over the weekend if you do??
will do.
Try living in Ilkley, its full of pensioners in the day and by night its full of chavs who come over from Leeds/Bradford!
will do.
the chavs are from Yeadon and Guisley!! All the 'Westside Crew' who hang around the mcdonald's in Guisley!! you have some great places to go swimming though :lol:
