Headlight Fuse
salmon81
Hi people,
I bought a hid conversion kit a few weeks ago and about a week ago 1 side failed, now the other side has failed.
I tried putting the original bulbs back in but they dont work so i'm guessing the fuse has gone.
Does anyone know where the fuse is for the headlights as i can't find it :sad:
Hope someone can help.
Salmon81
There are fuses under the bonnet. drivers footwell and passenger footwell. If you pull the covers off it should say which is which on the lid.
I'm guessing you can't put normal bulbs back in anyway - somebody else can probably confirm this bit.
I've found the fuse for the headlights now, the problem i had wasnt finding the fuse boxes but finding which fuses are which!
Thanks anyway.
Salmon81
on the back of each fuse box cover is a schematic showing the fuse layout and system
Hey had the same problem with mine... i think the ballasts got wet, then corroded and shorted inside... kept poping fuses...
They can be found in the fuse box next to the Battery... when standing over the passenger wing looking into the engine bay, there is a line of 3 x 10A miniblade fuses closest to the Battery on the right of the fusebox... check all 3... the fuses are sided.
