Owners Manual
bazwackit
Does anyone know where I can purchase an Aristo Vertex handbook. I received a GS300 handbook with the car but unfortunately this doesn't match the Aristo in a lot of different ways.
On the dash board, sometimes, 'ARS' lights up and in the handbook there is no mention of it. Anyone know what it stands for?
I also can't get the 'cruise control' to work after 70 mph. Is this the same with all Aristos?
Apart from these little niggly things the car is superb.
  • 1 month later...
The ARS light will be a dodgy MPH to KMH convertor, remove this and run the car in KMH and this should solve your problem or replace with a Blitz product.
Cruise control is Limited to 70MPH / 110KMH on the Aristo Vertex.
Yoshi.
www.lexusvertex.com
Sorry for the late reply.
Not sure about the ARS, don't have this light on the dash, ABS & TRC. As for the Cruise Control, I think you'll find it is to do with the limiter, had mine removed when having the KPH - MPH, so far the cruise control has been taken to 130 on a night test just after I got the car. If it is the same as mine, you'll have an Up & Down Selector, Front & Back Selector as well as a button on the end.
If you ring this #, they will able to send you a replacement one for the Aristo, Mine is being done by this lot now.
Name - Imported HandBooks
Tel - 01423 885 723
Fax - 01423 887 564
Address - 2-164 Hookstone Drive, Harrogate. N. Yorkshire. HG2 8PF
E-Mail - post@importedhandbooks.co.uk
The owners name is Cath, not sure of her last name
  • 2 months later...
ars active rear steering
ars is not standard in uk lexus gs 300/430
light should come on with ignition then go out located third port hole bottom left rev counter
could be dirty or bad sensor
as for speed limiters car should be capable of 186 mph cruise at any speed
problem is with importers conversion from kmph to mph get an upgraded converter
