Fitting New Hu
its well easy
just pull back the top tray and it will slide off
pull back the snow/traction panel, that will also slide off
undo the 4 10mm bolts holding the headunit / heater in
remove unit
job done :)
oh,ill try that in the morning.ive just bought one of those amp bypass leads off eBay so ill be fitting that and running the cables for the sub and amp.the only problem i might have is my headunits internal amp is knackered but im gonna rewire the new speakers to the amp any way whats the easiest to do this without destroying stuff :unsure:
Can you email me a copy aswell please as i want to install an ICE system! my email is mubinibrahim@hotmail.com. The only problem i had was that when i removed the glove box i couldnt see the cable from the amp to connect to the iso cable? thanks mate
