Connector Problem
I got Xenon effect bulbs for my fogs an got my garage to fit them in. The only problem is the conector/bulb holder for the passenger side is different than the rest, is that normal?! The bulb i have will not fit in that holder, its fitted fine on the driver side. Does anyone know where I could get this bulb holder? Or what the part number/ID is? I hope I haven't confused anyone if ive not explained the part right. Its a brown clip thing into which the bulb fits into.
my lexus is a V reg 2000 model is200 SE Auto.
Any suggestions??
Thanks in advance :)
I got xenon effect bulbs for my fogs an got my garage to fit them in. The only problem is the conector/bulb holder for the passenger side is different than the rest, is that normal?! The bulb i have will not fit in that holder, its fitted fine on the driver side. Does anyone know where I could get this bulb holder? Or what the part number/ID is? I hope I haven't confused anyone if ive not explained the part right. Its a brown clip thing into which the bulb fits into.
Any suggestions??
They should be indentical on both sides, maybe previous owner had to replace it for some reason or else yours has melted due to water damage maybe. I'll try get you a part number for it from my mate that works in Toyota.
Any suggestions??
Part number should be: 90980-11096
Hey thanks a lot man!! Well wen i got the car the fogs didnt work, got garage to check it was heated an melted an all sorts, but the connector thats attached to the wire is fine, wire was a bit loose but guy fixed it, but it was just the whole fitting, the 9005 bulb which is the same as 9006 cannot fit into that holder on that side as it has like a completely different design to the rest of the holders on the car, its like a big fat chunk inside an it just takes a different bulb, i duno the bulb number as its currently fitted and i cant get into it without ramping it up.
But hey, thank you very much! I will fone lexus and ask if they can supply me with this or even do a search online. Thanks a lot man, i appreciate it.
Im glad people have these forums, it is very helpful :)
Cheers again mate
Cheers again mate
No bother mate you dont need to put the car up on a ramp to get at the fog bulbs, you can get to the fogs if you remove the whell arch liner. Theres some plastic pop screws that you need to take out first them just gently pull the liner towards you. You shouldnt be paying people to change your light bulbs!
