Diff Problems
Parf
Hi
Im having a problem with my altezza. Whenever I pull off and change gear in first and second when I let the clutch out i get a clunk. I noticed that when i turnt the driveshaft by hand theres a little play before it engages the drive shafts. Theres also a roaring noise if i let off going down hills.
Going by what Markrs200 says with the have you got a diff post as below
Look for the codes
ao1a-no diff
ao1b-have a diff
ao2a-no diff
ao2b-have a diff
so if this code ends in B it means u have a diff
Mine ends in a b so I should have one but when I jack both wheels and spin one the other doesnt turn.
Have I got a problem with my LSD or havent i got one.
easiest way to know if your car has LSD is to do a rapid take off with the TRC button off...
If it lays down TWO burn marks (no. 11's) then you have a LSD ;)
@Enda ... sorry but i think the oil in a torsen diff is only for lubrication..
thats what i thought too !
try the test but with one wheel on a slippery surface (dirt grass ect)
and pull away quickly
both wheels should spin and not just the one with out grip !
i was well impresed with how easy my diff locked up on friday !
i pulled over along a single track road to let oncoming trafic pass
one wheel on hard pack dirt and the other still on the black stuff.
just pulled away promptly and got tire squeel from the one on the tarmac !
