Power Steering Leaking - Alternator Problems?
The PS pumps on early LS400s are well known for leaking fluid from the pump onto the alternator below. You need to find a garage who can inspect the pump and determine if it's developed a leak or not.
hello maneesh, lutonmatt,
but are there any early signs of the alternator going bad or it just one day will not work???
regs
mine just went was driving one day then the lights come on on the dash and that was that new one on its way
how bad was your leak from p/sbefore it happened?
and how can I prevent it from happening...
regs
It's the 'O' ring that's gone flat on the bottom of the resovoir, dead simple fix, 3 bolts, turkey baster to suck out all the oil and a new 'O' ring, 10 minutes tops,
