Front Fogs
Tango
Looks like one of the bulbs has gone in my IS200 drivers side front foglight, and it's corroded in. Anyone have a spare or can point me in the direction of some non-OEM replacement units??? :unsure:
hi i have just replaced the passenger side fog light on altezza as200, ihave discovered, the is200 foglights have three different type of bulbs. up to 2003 the bulbs are hb4 after 2003 the bulbs are hb3 and the estate versions use h3 foglight bulbs. hope this helps.
Thanks for the info, if I can remove the original bulb that will be useful. Perhaps I didn't make myself clear, but I'm looking for spare foglight assemblies or non OEM replacements as I don't believe the bulbholders are going to be in a fit state to take a new bulb.
i had a similar prob when i wanted to change my bulbs. now this sounds harsh and others my kno a better way of getting a corroded bulb out so... but i disconnected the bulb plug n took a pair of mole grips to my old bulb. it only has to turn about an 1/8 of a turn then its just a matter of wriggling it backwards and forwrds to get it loose to pop out with a flat screwdriver. wd40 will help also. then clean it up and hey presto, new bulb ready to be fitted..
if not believe i saw a foglight on eBay the other day.
as regards to aftermarket options the appertures are big enough to fit a lot of lights into. would just be a matter of cutting off the lexus loom plug and matchin +/- up to make them work from the stalk switch. :D
