Workshop Manual
should do.. might be a prob with your browser..
if you around this weekend i may be able to help?
It doenst seem to work with firefox but works fine with IE 6 or 7
I got an El Cheapo cd. It had some Toyota diagrams etc. but not many. The instructions were of the form, remove trim a, remove trim b etc. In other words, it had no diagrams or photos and no instructions. As it happens the trim came off just by pulling off. But there was no way of knowing whether one piece of trim held down another, so you have no way of knowing whether you have to remove all the trim as suggested or can miss bits to get to the part of the car you wanted to access. But it was REALLY cheap.
cheers mate ill let you know
It is designed for IE browsers, I started to modifiy it to display correctly in firefox but I have not finished yet as the code is really badly written and it is a pain to cleanup. If you go to http://bahamutcars.com/workshop it will detect automatically your browser and link you to the suitable version.
I have the ones for the RX, GS and LS aswell but I removed them cause they take too much space on the server.
