Sprayed Headlights Today
coolrides
Look good matey what paint did you use? was it quite easy?
hard bit is getting the 2 nuts off behind the wheelarch liner. but is possible. take the wheels off for room to work.
i put mine in oven at 110 for 15 mins then took out and prized it apart. one at a time i did mine. quite stiff to pull apart tho until it lets go. once it comes apart make sure no glue is sitting outside the seal area or inside the light move it back into place while hot.
spraying i used grey primer with ford panther black, nice and metallic, then clear laquer. let dry overnight to harden a bit.
then to reasemble i got it together as best i could then reheat in oven to soften glue for 10 mins and then push all clips into home position. then leave in light down position or use vice grips to hold together till glue hardens. i didnt use grips and mine where fine. just made sure all clips had went in properly. good vidoe on utube too check it out. links on here somewhere.
good luck
Cheers matey mine need re-sealing so might aswell smoke em while there apart.
