Headlight Adjustment
The ones in the corner do left/right, and the ones on top do up down.
Careful though - they only have threads which can move the beam about an inch. Turn them anymore and you'll nacker the adjustments....
Yes as someone found out didn't they Zee <_<
No - it'll be fine pal. Just do it at night, up against a wall and tweak the screws to get them right. Take your time - and if you are too nervous, then take it to an MOT garage and they will be able to level it for you using the correct tools....
I'm not nervous about doing it. I'm only worried coz I gave them a tweak earlier before asking :whistling:
I just hope I didn't over do it! How will I know if I've broken them, or will it be painfully obvious next time I drive at night?
Is there a rough guide as to where they should be casting light when I park against a wall? How high should the beam be??
