Looking To Learn How To Weld
Fargo
You need a steady hand :D
I wouldnt bother learning arc welding just for basic stuff, its quite easy when you get the hang of it, but it can be a bit heavy, i didnt know you could still buy them now ?
mig welding is easy enough, never tried tig but im told its very similar to mig.
buy the biggest mig that you can plug into a 13a socket, otherwise you are limited where you can use it
then practice
then practice more
the idea in principle is simple enough and there are lots of reading material available, but it takes a while to be able to get all your settings right and produce good results
as john said arc is a bit archaic, mig is the best and easiest starting point, when you have mastered mig, move on up to tig
