Metallic Noise When Going Over Speed Bumps / Potholes
paul's is200
3 possibles I can think of:
Heat shields around exhaust system?
Rattling back plate on rear brake(s)?
Not sure if IS has "resonators" (large rubber weights bolted to exhaust) like the GS does, but if the rubber bush around the bolt deteriorates, they rattle.
i had this noise on mine most annoying!!!took the rear caliper off removed the rear drum and found a wee bit of metal it was the hand brake cable guide(fell off the backing plate)took this out rebuilt noise gone!!!
  • 8 months later...
