My remote keys have stopped opening and locking the doors on my LS430! all the locks work by using the pull out key manually.
Once inside, the lock/unlock button works all the door locks. Touching the handle locks all the doors... using the key manually opens the doors but sets off the alarm!
I was wondering if the remote receiver is fused and if so where can the fuse be found. I can find nothing in the book...
can anyone shed light?? Please.
Hi
If the 430 is anything like the 400 on this issue then you could do no better than to search this forum. If you havent disconnected the battery/had a flat Battery then the Battery within the remote could be the problem. If youve not changed it for a year (2 at the most) that would be a good and easy starting point.
Steve
Hi
If the 430 is anything like the 400 on this issue then you could do no better than to search this forum. If you havent disconnected the battery/had a flat battery then the battery within the remote could be the problem. If youve not changed it for a year (2 at the most) that would be a good and easy starting point.
Steve
Hi Steve thanks for the reply, but I changed the batteries on both
fobs, so its isn't a lack of power from the remote.
I have searched this site but cant find much that is relevant to the 430! I may have to bite the bullet and take it to the stealership.
Thanks again.
