Annoying Squeeky Clutch
fipsy
Good morning boys and girls. As the title says, ive got a squeeky clutch. Its not the peddle as u can definitely hear it louder outside than inside. Ive had a look under the bonnet and under the car while my mate pressed the peddle but could not see anything moving. Is there a cure? Anybody had this before?
ive currently got this, well comes and goes...its down to the clutch plate...apparently for the annoyance, its a job and a half to get to the clutch to clean plate etc
i plan to get clutch changed soon so hopefully everything will be ok..
Pretty common issue with the manuals. Mine does it but more so in winter. Try some graphite powered around the fork & slave cylinder as that's the area where the noise comes from.
