Altezza Lsd Help Asap
keeperlti19
I know the sports LSD has 3 holes for the drives and the altezza LSD has 6 holes I think. The problem is I cant find a sports LSD so im going to fit an altezza LSD and two altezza drive. does anyone know will the altezza LSD and drives fit a lexus is200 help asap?
  • 4 weeks later...
i know buff
the reason i would swap the shafts with the diff is, that its a matched set, the altezza shafts are in effect the same(just shorter) however the output shafts from the diff unit are better designed, not especially stronger, but they do use more bolts than the is200 4 stud and nut method
i think if you can its better to use the output/half shafts that come with the unit rather than popping them out, and potentially damaging the oil seal, or worse bearings
