I guess you mean the gasket between "after the CAT" and flange for the start of the "Y section" part of the exhaust.
Get inderneath and have a good look. I suspect that the nuts for this joint are seized and rusted beyond use.
Mine were, so I sealed the gap with some exhaust paste and with 2 jubilee clips together, I put them around the joint to squeeze in and hold all the paste in place. This lasted for over a year, fo2 2 MOTs and was a quick cheap fix.
I know that others have has this joint welded up with success too.
im looking for th fiber gasket /washer things that fit in the front joint on my 96 LS400 as my exhaust flange is blowing on that joint
Three years ago, I had one of these fail on my '96. It costs £4.50 if I remember. If you are doing the job yourself, why not get one from the Main Agent? The whole job cost me about £50 - less than a tank of fuel, even then.
cheers guys car sits so low i cant see underneath a manic friend of mine looked yestergay and said its the front joint so im guessing the Y piese he also said about fibor gasket after over 2 hours on line last night i found some in the states
That's a long way away to source a couple of exhaust gaskets - I have just bought a pair from Lexuspartsdirect.co.uk (Lexus Swindon) at £ 3.33 each, including postage.
They are easy to fit once you get the old bolts out. Mine were so corroded that I had to drill all of them out.
Regards
Alan
Lexus main dealer quoted over £1600 for this job so I looked around before I let them on it. Then whilst I was having my tracking adjusted (darned potholes) and it was on the ramp the local exhaust centre asked me if I knew I had a leak (it was obvious considering the baubling noise) and did I want them to fix it. I had both sides fixed and they charged £20.00.
It is now quieter than I ever remember it being. :o)
Good result. My main dealer quoted me over £900 for suspension work, but the car has passed three MOTs since without any mention of such work. Hmmm...
well im hoping just the gasket
it will be mate,
happened to me on my 93, bloke only charged me £15 for gaskets & fitting, but he said he wont work on my car again with jobs underneath it as all the bolts took ages burning off, so it would help if you knew a mechanic bloke :winky:
