Lexus Is200 Overheating
My Lexus IS200 is overheating. I noticed it was only doing this in stationary traffic. After some investigation I discovered the radiator fan is not kicking in when it should. In fact it never kicks in. I checked the fuse. That looks ok. I'm beginning to think its the fan switch. Can anyone tell me where the fan switch is and how to check it? Has anyone had the the same experience?
i cant say for sure but for the time and cost involved to check/replace fuses it would definately be my first move-there is a thread a bit like yours if you search which may help when a guy had his timing belt replaced and fan didnt kick in due to garage not reconnecting fanswitch plug - he managed to keep his cool in an emergency by putting heaters on max and fan in cabin on high - not reccomended in general but worth bearing in mind if you get in that position again
Just a thought. My car has two radiator fans. Each fan is controlled by a dedicated relay (switch) in the fuse box i.e. there are two relays in the fuse box. Am I correct in thinking, unless BOTH relays are faulty, if neither of the fans operate when they should kick in, the likely culprit is the temperature switch (on which both rely to get the cue to switch on)?
